- To:
- Subject: Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp
- Date: Wed, 20 Jun 2018 10:36:01 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Wednesday, June 20, 2018 10:05:48 AM CEST J. Scheurich a écrit :
> > There must be something fishy here. See for example our test results
> > here:
> > https://cgal.geometryfactory.com/CGAL/testsuite/results-4.13-I-34.shtml
> > You'll see that the line Surface_mesh_Examples where sm_circulators.cpp
> > is tested can be compiled and ran successfully on all our test platforms
> > (that includes some of yours).
> Sorry for the table, it is misleading. sm_circulators.cpp failes only
> under fedora 28 (not in the list of the tested systems) but i get
> the exception of it under also under Debian and Arch Linux when i do
In the CGAL test results, all the test platforms named Fedora<something> (but
not Fedora-rawhide) are using the last public version of Fedora: Fedora 28.
Laurent Rineau, PhD
- [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/20/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, j. scheurich, 06/21/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/21/2018
