- To:
- Subject: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp
- Date: Tue, 19 Jun 2018 16:02:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
When i try to compile
https://doc.cgal.org/latest/Surface_mesh/Surface_mesh_2sm_circulators_8cpp-example.html
i get the following exception:
$ g++ test_cgal.cpp -lCGAL
$ ./a.out
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: _idx < data_.size()
File: /usr/include/CGAL/Surface_mesh/Properties.h
Line: 173
Aborted (core dumped)
I tried CGAL 4.11 and CGAL 4.13 without success on Fedora Linux 28.
How can i fill a Surface_mesh with data (without a Off file...).
so long
MUFTI
- [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/20/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, j. scheurich, 06/21/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/21/2018
