- To:
- Subject: Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
- Date: Thu, 19 Sep 2019 11:11:13 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
I am trying to do something similar. I want to merge two meshes and after
merging there will be shared vertices and edges. which means it will be
non-manifold. How can I do this? Can you refer to examples?
I have attached the snapshots here.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/28.png>
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/29.png>
After merging these two meshes, it should be look like this
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/30.png>
And there will be shared connected vertices.
Thanks
Shrabani Ghosh
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/19/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/25/2019
