- To:
- Subject: Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
- Date: Fri, 20 Sep 2019 10:19:45 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I already tried the union. But it's coming out as the union operation could
not be computed.
I tried with different input files, it works but with my two input files, it
does not work. Is it possible because of coordinates?
Regards
Shrabani Ghosh
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/19/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/25/2019
