- To:
- Subject: Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
- Date: Wed, 25 Sep 2019 06:55:39 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
It does not work because the output is full of non-manifold edges
(you are doing the union of 2 surfaces extracted from marching cube so
if is expected to have such edges).
Sebastien.
On 9/20/19 5:19 PM, Shrabani Ghosh wrote:
I already tried the union. But it's coming out as the union operation could
not be computed.
I tried with different input files, it works but with my two input files, it
does not work. Is it possible because of coordinates?
Regards
Shrabani Ghosh
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/19/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Shrabani Ghosh, 09/20/2019
- Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes, Sebastien Loriot (GeometryFactory), 09/25/2019
