cgal-discuss - Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
  • To:
  • Subject: Re: [cgal-discuss] [PRUDENCE_MESSAGE_SUSPECT]Re: Merging two surface meshes
  • Date: Fri, 20 Sep 2019 10:31:59 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
If you are doing a union, you will have issues only if you are
for example trying to make the union of two cubes sharing only
an edge or a vertex. Otherwise, it should be fine.
Sebastien.
On 9/19/19 6:11 PM, Shrabani Ghosh wrote:
Hi,
I am trying to do something similar. I want to merge two meshes and after
merging there will be shared vertices and edges. which means it will be
non-manifold. How can I do this? Can you refer to examples?
I have attached the snapshots here.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/28.png>
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/29.png>
After merging these two meshes, it should be look like this
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/30.png>
And there will be shared connected vertices.
Thanks
Shrabani Ghosh
