- To:
- Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
- Date: Thu, 2 Apr 2020 10:56:50 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:heo61RWqTTLlVXFIFbax/G4wo5zV8LGtZVwlr6E/grcLSJyIuqrYZRyDt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aSV3DMl9+Ke3xX4LTlM+qzPua+pvJYgwOiiDuT6l1KUD8lgjbv9IKgIZkYoI20BrOvjMIVOlRwG50P0O9lh3g4d2hvdQrpz9UvOgg8NIGVKHScKExTLgeBzMjZTNmrPb3vAXOGFPcrkAXVX8bx0IRX1r1qSriV5K0iRPU8/Jn0XDDb8LzRLEwHz+l6vUzEU66uGI8Lzc8tVrvpIl1haNfrgimokUmkYHRaYCRcvF5e/GEJI5IdS96Rs9UEhd5LMa8Yo8IVbdTOO9Zq8zivQJLo0biQwarA+zrx3lDgXqkhaA=
I'm just saying that sometimes people have to stick to a given version because they are using a package manager and they have to stick to
that version.
Since you are using a "manual" installation I was wondering why not using CGAL 5.0.2
You should review the Installation instructions here
https://doc.cgal.org/latest/Manual/windows.html#title8 and see what you haven't done.
If you want to give vcpkg a try there is some documentation here:
https://doc.cgal.org/latest/Manual/windows.html#title1
Sebastien.
On 4/2/20 10:32 AM, AliiAsgharii wrote:
Hi Sebastien,
I already tried to use the package manager (vcpkg) if you mean but because I
already set everything with the lower version, I thought if I change the
path I could not even run the simple code.
It is also a bit vague about the process of using VCPKG.
Do you think if I go with package manager, my problem would be solved?
Is there any clear document for using this?
Best regards,
Ali
- [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Guillaume Damiand, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Sebastien Loriot (GeometryFactory), 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/03/2020
