cgal-discuss - Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
  • To:
  • Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
  • Date: Fri, 3 Apr 2020 04:33:05 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
The first time I used vcpkg for installing qt but while complaining I got the
same error. Then I installed Qt separately.
Yes I used toolchain as specified in the document (select Specify toolchain
file for cross compilation (the file vcpkg.cmake within the directory where
you have installed vcpkg, e.g.
C:/dev/vcpkg/scripts/buildsystems/vcpkg.cmake).)
I am quite sure if I uninstalled the qt I will get the same error. I will do
that though to see what happens.
