- To:
- Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
- Date: Thu, 2 Apr 2020 11:10:07 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I do think that cleanly removing QGLViewer could fix a lot of problems.
I'm just saying that sometimes people have to stick to a given version
because they are using a package manager and they have to stick to
that version.
Since you are using a "manual" installation I was wondering why not
using CGAL 5.0.2
You should review the Installation instructions here
https://doc.cgal.org/latest/Manual/windows.html#title8 and see what you
haven't done.
If you want to give vcpkg a try there is some documentation here:
https://doc.cgal.org/latest/Manual/windows.html#title1
Sebastien.
On 4/2/20 10:32 AM, AliiAsgharii wrote:
> Hi Sebastien,
> I already tried to use the package manager (vcpkg) if you mean but because I
> already set everything with the lower version, I thought if I change the
> path I could not even run the simple code.
> It is also a bit vague about the process of using VCPKG.
> Do you think if I go with package manager, my problem would be solved?
> Is there any clear document for using this?
> Best regards,
> Ali
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
- [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Guillaume Damiand, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Sebastien Loriot (GeometryFactory), 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/03/2020
