- To:
- Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
- Date: Fri, 3 Apr 2020 11:23:38 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:rg1m9xAO3gWsZufJ2LQvUyQJP3N1i/DPJgcQr6AfoPdwSP76oMbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760DgJBx+qNRZpPv+nXcnJnsGv3qaz/YfSakNGnn2mcLZqJVK3qwvW8cIZiI8nJqcqwQbSuSh0fLFdympsYF6ShB3h/dyY/Zh58i0Wtehy2dRHVPDfdrQ5SLEQIzUjPmYyrJnuvAnCSAbJ6XoZX2MRuhVNCgnBqhr9W8Gi4WPBquNh1XzCboXNRrcuVGH6tvs5eFrTkC4CcgUB3iTPkMUp1fBUpRugo1p0xIuGONjEZso7RbvUeJYhfUQEW89QUyJbBYblNtkACuMAOaBTqIyv/gJT/yv7PhGlAabU8hENhnLy2vdkgeEoEAWD2w15WtxX4C6So9LyO6MfF+uyyfuQwA==
Qt5_DIR:PATH=C:/dev/Qt/Qt5.14.2/5.14.2/msvc2017_64/lib/cmake/Qt5
It should be found from vcpkg. Are you using the toolchain as specified in the document ?
I also attached a screenshot of my Cmake.
<http://cgal-discuss.949826.n4.nabble.com/file/t376202/Cmake_1.jpg>
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, (continued)
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Sebastien Loriot (GeometryFactory), 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/02/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/04/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/05/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/06/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/07/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/07/2020
