cgal-discuss - Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
  • To:
  • Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
  • Date: Sat, 4 Apr 2020 12:03:32 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi Maxime,
I think this time I have everything with vcpkg correctly installed and I
have also done the process through the Cmake perfectly.
Now when I am trying to build and compile the draw_triangulation_2, I face
the following error without any result of representing the triangle.
Done building project "draw_triangulation_2.vcxproj" -- FAILED.
I have attached the CMakeCache here. I do not have any idea what the problem
can be.
I also attached the figures regarding the errors.
<http://cgal-discuss.949826.n4.nabble.com/file/t376202/Error_0.jpg>
<http://cgal-discuss.949826.n4.nabble.com/file/t376202/Error_1.jpg>
CMakeCache.txt
<http://cgal-discuss.949826.n4.nabble.com/file/t376202/CMakeCache.txt>
Would be appreciated if you can give me any clue.
Best regards,
Ali
