- To:
- Subject: Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER
- Date: Sun, 5 Apr 2020 08:54:10 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:1jHtyhNE+Y0n42dmbxcl6mtUPXoX/o7sNwtQ0KIMzox0K/r9rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZFRz7cAZ0Pe/oAZX6jsKt1un09YeATR9PgW+UZbJzBQ65rQzLt8he1YJmK+A40RTJq2FJPeVL3n9AKleanhK67cC1qs0wux9Msu4sopYTGZ7xeL41GOQBUWYWdlst7ciujiHtCAuC4nxFDzcQzlxOCgLP6By8VZD04HKj57hNnRKCNMizdogaHDGr7qNlUhjt0X5VODsw8WWRgct13vkC/ECR4idnyouRW7m7ceJkd/qEL9wfTGtFGM1WUn4ZDw==
Hi Maxime,
Thank you for your all help.
I could handle this and successfully compiled an example regarding drawing a
polygon.
However, when I tried to draw a triangle and run that example, nothing was
drawn in the basic viewer.
This example reads the data from outside not inside the code. Do you have
any idea about this?
Just for everyone's information: I think the version of vcpkg released in
February 2020 had some bugs and I installed a lower version, then the
problem solved.
Best regards,
Ali
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, (continued)
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/03/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/04/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/05/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/06/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/07/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Maxime Gimeno, 04/07/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Andreas Fabri, 04/07/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/08/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Sebastien Loriot (GeometryFactory), 04/06/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, Andreas Fabri, 04/06/2020
- Re: [cgal-discuss] How to define CGAL_USE_BASIC_VIEWER, AliiAsgharii, 04/06/2020
