- To:
- Subject: Re: [cgal-discuss] Docker based headers-only CGAL usage
- Date: Wed, 13 May 2020 13:22:06 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
"headers-only CGAL" and "only compile our own source code" in the same sentence does not make sense to me.
I guess you want to create a small library with a CGAL-free interface (=a header without CGAL mentioned inside). All CGAL parts would be
used only in the lib associated to that header.
Best regards,
Sebastien.
On 5/13/20 1:07 PM, Yoni Goyhman wrote:
Hello, we have a CGAL based project we are working on, setup with Docker.
We are using different parts of the CGAl library, and have come to a point where every build that requires compilation takes a very long time (sometimes over 15 minutes).
We would like to create a headers-only CGAL Docker configuration so we don't have to compile CGAL everytime, and can only compile our own source code.
Is there a guide / example project that can help us achieve that?
Thank you
Yoni Goyhman
CTO
<mailto:>
+972-544-686890
WeWork Sarona, Aluf Kalman Magen St 3Tel Aviv, Israel 6107075
- [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Sebastien Loriot (GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Maxime Gimeno, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Laurent Rineau (CGAL/GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Giles Puckett, 05/14/2020
