- To:
- Subject: Re: [cgal-discuss] Docker based headers-only CGAL usage
- Date: Wed, 13 May 2020 13:22:44 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ZfaUJxKSOcwim5ljJtmcpTZWNBhigK39O0sv0rFitYgeKPzxwZ3uMQTl6Ol3ixeRBMOHsq8C2rad6PCocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbAhEmTqwbal2IRi5ogncuMobipZ+J6gszRfEvmFGcPlMy2NyIlKTkRf85sOu85Nm7i9dpfEv+dNeXKvjZ6g3QqBWAzogM2Au+c3krgLDQheV5nsdSWoZjBxFCBXY4R7gX5fxtiz6tvdh2CSfIMb7Q6w4VSik4qx2ThLjlSUJOCMj8GzPhcNwgqBUrhKvqRJ83oDafp2aOeFkca/BZ94XX3ZNUtpTWiFHH4iyb5EPD+0EPetAqIfyvVQPrRq7BQayGejhyz5Ihnro0q081OQqDAbL3Ak6ENMBsXTUqcv6OL0dUeC0yanH0zPDb/RN1Dfy7YjHaBEhofWWUb1sdsrRzFAiGgXYhVqftYLrJSma1vgRs2eF9epgU/qihWEopQ9xoDWhyMMhh4bLi44I1FzI6zh1zZo3KNO4SUN2bt6qHZtUui2HN4Z7TcIvTW5mtSs01rAItpG1cSsWxJkh2hXRaOSHfpCW7h7/UOudOzR1iXJ/dL6hmhq+7VKsx+LiWsSyzV1EtDBKksPWuXAIzxHT6taISv96/kq53DaAzQHT6uVdLUAziarXNoctwrA/m5YNq0jDESj2mEL5jK+SaEoo4PSn6+PiYrn+p5+cMZF7ih3mP6gwhsCyBf40PwsOUmSB5+iwyaHv8Vf2TblUlvE2l7PWsJHeJcQVvK65BApV354m6xmlADam0dEYkmcdIFJKeRKHipbmO1fJIP3jAve/hk6jkDZvx/zcIrLhBZDNImDZkLj9ZbZ991JcyA0rwN9D6JJbELUBLOvuVU/wr9zXEgI5Mxevw+v8E9V81oYeWXqVDaODMaPSt0WI5uM1LOWWao8VomW1F/9w7PHniTo1mEQWYLKy9ZoRcnGxWPp8cGuDZn+5p94REGIH9iU/SeHsjxXWVDdDZnO/Ga094zw9D6qpCI7CQsamh7nXj3TzJYFfem0TUgPEKnzvbYjRA65QOhLXGddol3k/bZbkU5UojEj8uwrzyr4hJe3RqHVB5MDTkeNt7uiWrikcsDl9DsCTyWaIFjgmkWYBRjtw16d68xUklwWzlJNgivkdLuR9ovNEVgBgaMzZxu1+TtfuA0fPIo3PR1GhTdGrRzo2S4Bpzg==
Hello,
CGAL is header only by default, so I am unsure of what you are trying to do. I'd say that to be quicker, you'd want to build cgal as a classic library, and only link with it in your runs.
Maxime Gimeno
Hello, we have a CGAL based project we are working on, setup with Docker.We are using different parts of the CGAl library, and have come to a point where every build that requires compilation takes a very long time (sometimes over 15 minutes).We would like to create a headers-only CGAL Docker configuration so we don't have to compile CGAL everytime, and can only compile our own source code.
- [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Sebastien Loriot (GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Maxime Gimeno, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Laurent Rineau (CGAL/GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Giles Puckett, 05/14/2020
