cgal-discuss - Re: [cgal-discuss] Docker based headers-only CGAL usage
  • To:
  • Subject: Re: [cgal-discuss] Docker based headers-only CGAL usage
  • Date: Wed, 13 May 2020 14:08:14 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:DKqTmBOd0Z0W5/iduy0l6mtUPXoX/o7sNwtQ0KIMzox0Iv79rarrMEGX3/hxlliBBdydt6sZzbuK+Py/EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCe9bL9oKBi7ogrdu8YUjIB/Nqs/1xzFr2dSde9L321oP1WTnxj95se04pFu9jlbtuwi+cBdT6j0Zrw0QrNEAjsoNWA1/9DrugLYTQST/HscU34ZnQRODgPY8Rz1RJbxsi/9tupgxCmXOND9QL4oVTi+6apgVRnlgzoFOTEk6mHaksN/jKxZrxyhqRJxwJPabp+JO/dlZKzRYckXSHBdUspNVSFMBJ63YYsVD+oGOOZVt47zqEEBrBu/AAmjGv7kxD5Jhn/zw6I61eMhGhzB0QwlBd0Pv3XUrNDrO6sIXuC1zazIwivFb/NRwjr9543IfQogofGIR75/bc3RyUw2Gg7Dk16fppDrMSmP2eQRr2iU8fBgVeS3hmAopA9/ojqiyMkoh4TGhI8Z107I+TtkzIspJ9C2SE92bNGkHpZQsyyWKot7T8wjTm9ntis3xKELt5G0ciUJ1JgqwQPUZf+fc4WQ/B7vSOKcLS17iX9lYr6zmhe//Eq6xuHhVcS4zVBHpTdfnNbWrHACzRnT59CHSvRj+keh3i6C1wXJ5eFFJUA4jK3bK588zrIpmJofrEfOEjLslEX5i6+WcUok+uy25Oj9frrmoZqcO5d1igH4LKsuhtSyDfokPgUKRWSW+uSx2Kf+8UD4QrhGlOA6n6rEvJzCIMQUvK+5Awtb0oY57Ba/Ci+r0NECkngILVJFfQyIg5LmO1HPJfD3E/G/g1O3nTdkwvDJJLzhApHXInffl7fheK5x61RAxwor0dBf+5VUB6kdL/L8QEDxsMXUAQI4Mwyv3+nnFc591pgFVGKUAq6ZNbvSvkWS6uIuJemMfo4VtyznJ/gr/f69xUM+zFQSdK3s0ZoMY22jBdxnJV+YaDzimIQvC2AP6y83XO3vhRWtUDteYXH6C6c19jA+BcSpDILOQIeFj7mI3SP9FZpTMDMVQmuQGGvlIt3XE8wHbzifd5c4zm40EIO5Qopk7imA8RfgwuM+fOXR8ywc85nk0YotvrCBpVQJ7TVxSv+l/SSNQmVzxD1aQjY32OV4oBU4xA7TiO53hPtXEdEV7PRMAF9jZMzsitdiAtW3YTrvO9KASVKoWNKjWGhjQdc4wttIaEF4SYyv
The only solution I see is Sebastien's, then.
Le mer. 13 mai 2020 à 13:28, Yoni Goyhman <> a écrit :
I guess I said something stupid :)
I'll refraze - What is the best way for us to use CGAL without having to compile the library every time?
Hello,
CGAL is header only by default, so I am unsure of what you are trying to do. I'd say that to be quicker, you'd want to build cgal as a classic library, and only link with it in your runs.
Maxime Gimeno
Le mer. 13 mai 2020 à 13:08, Yoni Goyhman <> a écrit :
Hello, we have a CGAL based project we are working on, setup with Docker.
We are using different parts of the CGAl library, and have come to a point where every build that requires compilation takes a very long time (sometimes over 15 minutes).
We would like to create a headers-only CGAL Docker configuration so we don't have to compile CGAL everytime, and can only compile our own source code.
Is there a guide / example project that can help us achieve that?
Thank you
Yoni Goyhman
CTO
+972-544-686890
WeWork Sarona, Aluf Kalman Magen St 3Tel Aviv, Israel 6107075
Yoni Goyhman
CTO
+972-544-686890
