- To:
- Subject: Re: [cgal-discuss] Docker based headers-only CGAL usage
- Date: Wed, 13 May 2020 14:27:01 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:T8ag2hVDSCCZbjIYvubAxQMOb3XV8LGtZVwlr6E/grcLSJyIuqrYYxOFt8tkgFKBZ4jH8fUM07OQ7/m9Hz1cqs3R+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aFRrwLxd6KfroEYDOkcu3y/qy+5rOaAlUmTaxe7x/IAi2oAnLssQbjoRuJ6gyxxDUvnZGZuNayH9yK1mOhRj8/MCw/JBi8yRUpf0s8tNLXLv5caolU7FWFSwqPG8p6sLlsxnDVhaP6WAHUmoKiBpIAhPK4w/8U5zsryb1rOt92C2dPc3rUbA5XCmp4ql3RBP0jioMKjg0+3zVhMNtlqJWuB2upxJ9zIDUbo+bN+dwcL3Bct4BX2VNQtxcWjZdDo+gbYYCCfcKM+ZCr4n6olsDtRmxBQ6qBOPu1zRGh3j23K060+QkCw7G2hErEtUOsXTTqtX1NbwfXvurw6bSyDXDcutW1S3n54jJax0sp+yHUr1sf8TL00YvCx/FgUuKqYzjJz6Y1OoAvmyH4+Z9VeyihHAqpQFvrzWs2MshhJXEi54Rx13F6Cl0wIQ4KNKmREB1f9OpEIZcuj2GO4ZrXs8vTH1ltSAnwbMFoZ62ZDYGxIgjyhLFaPGKc5KE7gz+WOuTOzt1i2xpdbSijBio60eg0PfzVsys3VZKsCVFlt7Mu2gI1xPJ68iHTuJx/lm62TqSzgzT5O5JLV4umarULJ4hxbEwlp4NvkjZAiD2n0D2gLeXdkUi5Oeo9/zqbqv6qpKYLYN5iQHzPr4wlsCiA+k0KAcDU3aD9eS5zrLj/En5QLtQjv0xl6nUqJDbJcMdpq64GAJayZgs5Ay6Dze7yNQUh2MILFNddBKdk4fpI03OIOz/Dfqnn1usny1kx/TfMrL8A5XNNWTMkKr6fbZm8ENc0woyzdVH551OEL0BIfTzWlXwtNPCFBM5PRa0kK7bD4B22YoaHG6OGaSEK7j6sFmS5+tpLfPfSpUSvWPMLP4kr9HpnH88kFlVKbiu25o/Yn2xG+l+ZUyYNym/yuwdGHsH61JtBNfhj0ePBGYKOiSCGpkk7zR+M7qISIfOQof33e6E1Sa/W4NNPyVIVgrKHnDveIGJHfwLbXDKe54zonk/TbGkDrQZ+1SrvQ7+xaBgK7ONqCcVvJf+zJ585r+LzE1gxXlPF82Yllq1YSRshGpRHm080al6vFQ7w1bRiaU=
I guess I said something stupid :)
I'll refraze - What is the best way for us to use CGAL without having to compile the library every time?
Hello,CGAL is header only by default, so I am unsure of what you are trying to do. I'd say that to be quicker, you'd want to build cgal as a classic library, and only link with it in your runs.Maxime GimenoHello, we have a CGAL based project we are working on, setup with Docker.We are using different parts of the CGAl library, and have come to a point where every build that requires compilation takes a very long time (sometimes over 15 minutes).We would like to create a headers-only CGAL Docker configuration so we don't have to compile CGAL everytime, and can only compile our own source code.
- [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Sebastien Loriot (GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Maxime Gimeno, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Yoni Goyhman, 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Laurent Rineau (CGAL/GeometryFactory), 05/13/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Trần Anh, 05/14/2020
- Re: [cgal-discuss] Docker based headers-only CGAL usage, Giles Puckett, 05/14/2020
