- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Thu, 27 Aug 2020 19:30:52 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi all,
I urgently need to do some analysis on non-2-manifold objects. How is it
possible to install the master version of CGAL (A straightforward
instruction please)?
Is it possible to use draw_nef_3 example in case of a successful install?
Any help regarding this would be appreciated.
Best regards,
Ali
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 08/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Maxime Gimeno, 08/28/2020
