cgal-discuss - Re: [cgal-discuss] Visualize non-2-manifold object
  • To:
  • Subject: Re: [cgal-discuss] Visualize non-2-manifold object
  • Date: Fri, 28 Aug 2020 06:24:01 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I have the Qt installed and I am already drawing 3D objects, the 2-manifold
ones with the 3D polyhedral surface library and mesh surface library.
I could see there is an update on CGAL version 5.1 which enables us to draw
the non-manifold objects. However, the formal 5.1 version has not been
released yet and also the examples for this version are still not available.
I was wondering if I could install the beta or master version using VCPKG
and using the examples regarding the nef_3 for doing some analysis around
non-2-manifold objects with the visualisation.
