- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Fri, 28 Aug 2020 13:47:39 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
if the --head option doesn't work, then you cannot. Either use the master branch on github, either wait for the next release, probably next week.
Le ven. 28 août 2020 à 13:24, AliiAsgharii <> a écrit :
I have the Qt installed and I am already drawing 3D objects, the 2-manifold
ones with the 3D polyhedral surface library and mesh surface library.
I could see there is an update on CGAL version 5.1 which enables us to draw
the non-manifold objects. However, the formal 5.1 version has not been
released yet and also the examples for this version are still not available.
I was wondering if I could install the beta or master version using VCPKG
and using the examples regarding the nef_3 for doing some analysis around
non-2-manifold objects with the visualisation.
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 08/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Maxime Gimeno, 08/28/2020
