cgal-discuss - Re: [cgal-discuss] Visualize non-2-manifold object
  • To:
  • Subject: Re: [cgal-discuss] Visualize non-2-manifold object
  • Date: Fri, 28 Aug 2020 08:57:50 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I think you need the [qt] option in the vcpkg command too, if you want to draw things.
So you should probably use
  vcpkg.exe install --head cgal[qt]
Le ven. 28 août 2020 à 02:31, AliiAsgharii <> a écrit :
Hi all,
I urgently need to do some analysis on non-2-manifold objects. How is it
possible to install the master version of CGAL (A straightforward
instruction please)?
Is it possible to use draw_nef_3 example in case of a successful install?
Any help regarding this would be appreciated.
Best regards,
Ali
