- From: Benjamin Werner <werner AT pauillac.inria.fr>
- To: Christine.Paulin AT lri.fr
- Cc: pperatto AT hotmail.com, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] dependent types
- Date: Mon, 24 Mar 2003 13:03:19 +0100 (MET)
Just to add my two cents:
On the other hand, most of the time there should be no need for having
a computational Set type depend upon a non-computational proof of
A\/B.
Mybye you can say a few words about why you want this ?
Cheers,
Benjamin
> No you are right, it is not possible to do an elimination on o:A\/B
> in order to build a proof of (P o):Set.
> The distinction between Prop and Set is that the computation
> of objects in Set does not need information on object in sort Prop.
> In your rule you will have
> o:A\/B f1:(x:A)(P (or_introl x)) f2:(y:B)(P (or_intror y))
> Case o of (or_introl x) => (f1 x) | (or_intror x) => (f2 y) end :(P o)
> Because (P o):Set one needs to be able to compute
> but without knowing the proof of A\/B which has type Prop, it is not
> possible to choose between f1 or f2
> C. Paulin
> Patricia Peratto writes:
> > Than you very much.
> > But I want to define dependent elimination over Sort
> > Set. I couldn't. Is not allowed?
> > Patricia Peratto
> > ----- Original Message -----
> > From: "Christine Paulin"
>Â <Christine.Paulin AT lri.fr>
> > To: "Patricia Peratto"
>Â <pperatto AT hotmail.com>
> > Cc:
>Â <coq-club AT pauillac.inria.fr>
> > Sent: Sunday, March 23, 2003 1:48 PM
> > > You may use the following declaration
> > > Coq < Scheme or_elim := Induction for or Sort Prop.
> > > or_elim is recursively defined
> > > Coq < Check or_elim.
> > > or_elim
> > > : (A,B:Prop; P:(A\/B ->Prop))
> > > ((a:A)(P (or_introl A B a))) ->
> > > ((b:B)(P (or_intror A B b))) ->(o:(A\/B))(P o)
> > > In order to use it, when p has type (A\/B)
> > > there is the tactic
> > > Elim p using or_elim.
> > > C. Paulin
> > > > I'm trying to define a rule for or_elim with dependent types
> > > > as follows:
> > > > (A,B:Prop; P:(A\/B->Set))
> > > > ->((b:B)(P (or_intror A B b)))->(p:(A\/B))(P p)
> > > > with cases, but does not recognize p as formed
> > > > by constructors and asks type (P p) for the conclusion.
> > > > Is it not possible to define this rule in Coq?
> > > > Regards
> > > > Patricia Peratto
> > > Christine Paulin-Mohring mailto :
>Â Christine.Paulin AT lri.fr
> > > LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY
> Cedex
> > > LRI tel : (+33) (0)1 69 15 66 35 fax : (+33) (0)1 69 15 65 86
> LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud, 91405 ORSAY Cedex
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] dependent types, Patricia Peratto
- Re: [Coq-Club] dependent types,
Christine Paulin
Patricia Peratto
Christine Paulin
- Re: [Coq-Club] dependent types, Benjamin Werner
Christine Paulin
Patricia Peratto
Christine Paulin
