- From: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- To: Coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] suggestion
- Date: Fri, 26 Sep 2003 11:28:10 +0200
- Organization: Inria Rhones-Alpes
Yes. "Il suffisait d'y penser", I will apply your trick .
Although it is less explicit (one have to scan the code to understand it is not available as a Lemma) it's probably
a sufficiently good answer before considering extending the vernacular...
Thanks
JY
Jean-Christophe Filliatre wrote:
> what about offering "Conjecture": > > 1. Such propositions could not be used (of course) in other proofs, > but... > 2. The coq compiler would accept incomplete proofs and still check > for the correctness of what is present > > Interest ?: > > 1. Offers handling of partial but correct proof developments > (especially for long and difficult proofs) > 2. Enables maintaining of incomplete work (it is usually done through > comments, thus not sensitive to contextual changes) > 3. helps collaborative work > > Feasibility ? Doesn't seems unrealistic, is it ? It seems that replacing "Qed" with "Abort" in a proof script is exactly achieving this goal: the partial proof script is checked until the "Abort" but the lemma is not saved thus cannot be used. Lemma my_conjecture : ... Proof. proof script tentative. ... Abort.
Jean-Yves Vion-Dury Research Scientist | Xerox Research Centre Europe |
INRIA (sabbatical) 655 avenue de l'Europe, 38334 Montbonnot (FRANCE) Jean-Yves.Vion-Dury AT inrialpes.fr |
from France: 0 4 76 61 53 83 from abroad: +33 4 76 61 53 83 |
you may have a look at the Circus Transformation Language? | www.alphaAve.com |
- [Coq-Club] suggestion, Jean-Yves Vion-Dury
- Re: [Coq-Club] suggestion,
- Re: [Coq-Club] suggestion, Jean-Yves Vion-Dury
Claude Marche
Jean-Yves Vion-Dury
David Aspinall
- Re: [Coq-Club] suggestion, Claude Marche
Jean-Yves Vion-Dury
