- From: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- To: Coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] suggestion
- Date: Fri, 26 Sep 2003 12:18:16 +0200
- Organization: Inria Rhones-Alpes
Ooooops, forget my last remark. The error came form the "Qed" after the "Abort", sorry for the noise.
JY
Jean-Yves Vion-Dury wrote:
This sound interesting.
By the way, it appears the solution proposed by Jean-Christophe is restricted: the "Abort" generates an error message (and stop further processing) at compile time.
J-Y.
Claude Marche wrote:
"Jean-Christophe" == Jean-Christophe Filliatre
<Jean-Christophe.Filliatre AT lri.fr>
writes:
>> what about offering "Conjecture":
>> >> 1. Such propositions could not be used (of course) in other proofs,
>> but...
>> 2. The coq compiler would accept incomplete proofs and still check
>> for the correctness of what is present
>> >> Interest ?:
>> >> 1. Offers handling of partial but correct proof developments
>> (especially for long and difficult proofs)
>> 2. Enables maintaining of incomplete work (it is usually done through
>> comments, thus not sensitive to contextual changes)
>> 3. helps collaborative work
The solution proposed by Jean-Christophe is good for that purpose. For
collaborative work, it seems to me it is useful to allow
unproved propositions to be used later. In such case, a trick is to use a
tactic based on an unsound axiom:
Axiom I_am_unsound_do_not_use_me : False.
Tactic definition Admitted := Case I_am_unsound_do_not_use_me.
Then 'Admitted' will solve any goal magically...
Hope this helps,
>> Feasibility ? Doesn't seems unrealistic, is it ?
Jean-Christophe> It seems that replacing "Qed" with "Abort" in a
proof script is
Jean-Christophe> exactly achieving this goal: the partial proof script is
checked until
Jean-Christophe> the "Abort" but the lemma is not saved thus cannot be
used.
Jean-Christophe> Lemma my_conjecture : ...
Jean-Christophe> Proof.
Jean-Christophe> proof script tentative.
Jean-Christophe> ...
Jean-Christophe> Abort.
Jean-Christophe> -- Jean-Christophe> Jean-Christophe
Jean-Christophe> --------------------------------------------------------
Jean-Christophe> Bug reports: http://coq.inria.fr/bin/coq-bugs
Jean-Christophe> Archives: http://pauillac.inria.fr/pipermail/coq-club
Jean-Christophe> http://pauillac.inria.fr/bin/wilma/coq-club
Jean-Christophe> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Jean-Yves Vion-Dury <http://www.xrce.xerox.com/people/vion-dury/home.html> /Research Scientist/ * Xerox Research Centre Europe *
*INRIA* (sabbatical)
655 avenue de l'Europe,
38334 Montbonnot (FRANCE)
Jean-Yves.Vion-Dury AT inrialpes.fr <mailto:Jean-Yves.Vion-Dury AT inrialpes.fr> from France: 0 4 76 61 53 83
from abroad: +33 4 76 61 53 83
you may have a look at the *Circus* Transformation Language? www.alphaAve.com <http://www.alphaAve.com>
- [Coq-Club] suggestion, Jean-Yves Vion-Dury
- Re: [Coq-Club] suggestion,
- Re: [Coq-Club] suggestion, Jean-Yves Vion-Dury
Claude Marche
Jean-Yves Vion-Dury
David Aspinall
- Re: [Coq-Club] suggestion, Claude Marche
Jean-Yves Vion-Dury
