- To: David Aspinall <David.Aspinall AT ed.ac.uk>
- Cc: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>, Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>, Coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] suggestion
- Date: Fri, 26 Sep 2003 13:45:22 +0200
Indeed, there is an alternative that avoids tricks like Abort instead
of Qed or the use of a false axiom: use modules and functors. The FSet
contrib heavily use such functors
(http://www.lri.fr/~filliatr/fsets/index.en.html). For example, I made
a development that was assuming some graph implementation, by using a
functor taking as argument a signature for graph. To give you an idea,
it looks like (summarized):
Require FSetInterface.
Module Type Graph.
Declare Module Node : OrderedType.
Definition node := Node.t.
Parameter arc : node -> node -> Prop.
Declare Module NodeSet : S with Module E := Node.
Parameter successors : node -> NodeSet.t.
Axiom arc_and_successors :
(n,m:node)(arc n m)<->(NodeSet.In m (successors n)).
End Graph.
then possibly in another file,
Module GraphProperties[G:Graph].
Import G.
Inductive exist_path: node -> node -> Prop :=
| path_refl : (n1,n2:node)(Node.eq n1 n2)->(exist_path n1 n2)
| path_trans : (n1,n2,n3:node)
(exist_path n1 n2) -> (arc n2 n3) ->
(exist_path n1 n3)
End GraphProperties.
and again in another file
Module MyApplicationUsingGraphs[G:Graph].
So doing, you are able to make your development, while somebody
else is developing one or more implementations of the Graph module.
Also you may have noticed I was using the FSetInterface without
bothering about its implementation, indeed two different ones have
been given by their authors.
- Claude
>>>>> "David" == David Aspinall
>>>>>Â <David.Aspinall AT ed.ac.uk>
>>>>> writes:
David> Dear Coq'ers,
David> Interesting this has been raised. Although you may be able to
simulate
David> both cases with a proof control command (Abort) or using a false
David> axiom(!), I think it would be an excellent idea to extend the
vernacular
David> to make these important cases explicit. In particular, this
would help
David> not only readers of your scripts but also tools concerned with
David> generating and analysing proof scripts (something we are looking
at in
David> the Proof General Kit project).
David> For comparison, Isabelle's Isar language uses the words "oops" to
stop
David> the proof attempt and forget theorem, and "sorry" to stop the
David> proof attempt and retain the theorem --- morally there is a proof
David> obligation in this second case, although there is no way to
David> discharge the obligation later apart from rewriting the script
David> (as far as I know).
David> - David.
David> --
David> David Aspinall
| Claude Marché |
mailto:Claude.Marche AT lri.fr
| LRI - Bât. 490 | http://www.lri.fr/~marche/ |
| Université de Paris-Sud | phoneto: +33 1 69 15 64 85 |
| F-91405 ORSAY Cedex | faxto: +33 1 69 15 65 86 |
- [Coq-Club] suggestion, Jean-Yves Vion-Dury
- Re: [Coq-Club] suggestion,
- Re: [Coq-Club] suggestion, Jean-Yves Vion-Dury
Claude Marche
Jean-Yves Vion-Dury
David Aspinall
- Re: [Coq-Club] suggestion, Claude Marche
Jean-Yves Vion-Dury
