- From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
- To: Coq-Club AT pauillac.inria.fr
- Subject: [Coq-Club] Newbie - ackermann function, etc.
- Date: Sun, 13 Jun 2004 12:52:10 +0200
- Mail-reply-to: <sk AT mathematik.uni-ulm.de>
Hello,
as a newbie to coq I have some questions. As I'm used to functional
programs I tried to start with function definitions and extraction.
How can I switch from coq's nat to Haskell's Integer type? The former
uses much more memory.
How can I define recursive functions, e.g. the Ackermann function?
I found a definition which uses streams, but my try to define it
directly failed. Where can I find some hints? Is well-foundmess (Wf)
the right starting point?
Module Ackermann.
ackermann 0 n = n+1
ackermann m 0 = ackermann (m-1) 1
ackermann m n = ackermann (m-1) (ackermann m (n-1))
Require Import Arith.
Section Ackermann1.
Require Import Streams.
CoFixpoint nats_from (n:nat) : Stream nat :=
Cons n (nats_from (n+1)).
CoFixpoint col_from (n : nat)(x:Stream nat) : Stream nat :=
let v := Str_nth n x
in Cons v (col_from v x).
CoFixpoint ack_from (c:Stream nat) : Stream (Stream nat) :=
Cons c (ack_from (col_from 1 c)).
Definition ack_tab : Stream (Stream nat) :=
ack_from (nats_from 1).
Definition ack (m n : nat) : nat :=
Str_nth n (Str_nth m ack_tab).
(* Eval compute in ack 2 2. *)
End Ackermann1.
Extraction "ackermann" ack.
Extraction Language Haskell.
Section Ackermann2.
Require Import Wf.
Definition A : Set := prod nat nat.
Definition P (A:Set) : Type := nat.
Definition R (x y : A) : Prop :=
((fst x) < (fst y))
\/ ((fst x = fst y)
/\ (snd x < snd y) ).
Definition F (x:A) (f: A -> nat) : nat :=
match x with
| (0,n) => n+1
| (m,0) => f (m-1,1)
| (m,n) => f (m-1,f (m,n-1))
end.
This fails:
Fixpoint ack' (x:A) : nat :=
F x ack'.
Definition ack2 (m n:nat):nat :=
ack' (m,n).
End Ackermann2.
End Ackermann.
Sincerly,
Stefan
- [Coq-Club] Newbie - ackermann function, etc., Stefan Karrmann
- Re: [Coq-Club] Newbie - ackermann function, etc.,
Pierre Casteran
Stefan Karrmann
Pierre Casteran
- Re: [Coq-Club] Newbie - ackermann function, etc., Pierre Casteran
- Re: [Coq-Club] Newbie - ackermann function, etc., Stefan Karrmann
Pierre Casteran
Stefan Karrmann
Pierre Letouzey
- <Possible follow-ups>
- Re: [Coq-Club] Newbie - ackermann function, etc., Yves Bertot
Pierre Casteran
