- From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
- To: Coq-Club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Newbie - ackermann function, etc.
- Date: Tue, 15 Jun 2004 23:31:54 +0200
- Mail-reply-to: <sk AT mathematik.uni-ulm.de>
Pierre,
thanks for your reply.
Pierre Letouzey (Mon, Jun 14, 2004 at 05:55:49PM +0200):
> On Sun, 13 Jun 2004, Stefan Karrmann wrote:
> > as a newbie to coq I have some questions. As I'm used to functional
> > programs I tried to start with function definitions and extraction.
> > How can I switch from coq's nat to Haskell's Integer type? The former
> > uses much more memory.
> Well, for the moment, nothing fully automatic exists to replace nat by
> Integer (or Ocaml equivalent). It could be done, but would not be so
> simple:
> - In the case where you have only a type domain and a few operations, e.g:
> Parameter my_nat : Set.
> Parameter my_zero : my_nat.
> Parameter my_plus : my_nat -> my_nat -> my_nat.
> Then it is trivial to replace these axioms by efficient implementations
> when extracting:
> Extract Constant my_nat => "Integer"
> Extract Constant my_zero => "0"
> Extract Constant my_plus => "(+)"
> - But Coq nat is more than a type with a few operations: it has an
> inductive structure (data Nat = O | S Nat) and you can do matching on a
> nat value. So you need to translate this matching to Haskell Integer.
> Of course this can be done, but if you do it systematically, you loose all
> the interest of a translation to Integer. For example, plus in nat is
> defined by matching, and you would then obtain a linear-time plus in
> Haskell instead of the quasi-constant-time (+).
Would views help, cf. `Views: An Extension to Haskell Pattern Matching'
<http://www.haskell.org/development/views.html>?
quote:
view (Integral a) => Natural a of a = Zero | Succ a
where
natural 0 = Zero
natural n
| n > 0 = Succ (n-1)
| otherwise
= error "Natural: Natural view excludes negative values"
In a view declaration of the form
view c => s of t = k where d
is equivalent to
data c => s = k
d
and is valid if and only if d defines (only) a suitably named function
of type c => t -> s and [...]
At least the equivalent pure haskell implementation should help for
extractions to Haskell and Ml.
Sincerly,
Stefan Karrmann
- [Coq-Club] Newbie - ackermann function, etc., Stefan Karrmann
- Re: [Coq-Club] Newbie - ackermann function, etc.,
Pierre Casteran
Stefan Karrmann
Pierre Casteran
- Re: [Coq-Club] Newbie - ackermann function, etc., Pierre Casteran
- Re: [Coq-Club] Newbie - ackermann function, etc., Stefan Karrmann
Pierre Casteran
Stefan Karrmann
Pierre Letouzey
- <Possible follow-ups>
- Re: [Coq-Club] Newbie - ackermann function, etc., Yves Bertot
Pierre Casteran
