coq-club - Re: [Coq-Club] Newbie - ackermann function, etc.
chronological Thread
  • To: sk AT mathematik.uni-ulm.de
  • Cc: Coq-Club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Newbie - ackermann function, etc.
  • Date: Thu, 17 Jun 2004 10:01:53 +0200
  • Organization: LaBRI
Hello Stefan,
  You can find in Coq's standard library the module
Coq.Wellfounded.Lexicographic_Product
which proves that the lexicogrqphic product of two wf sets
is wf.
If you want to work with Z, you can use the order
 Zwf (c x y:Z) := c <= y /\ x < y.
which is wf too (see library Coq.ZArith.Zwf)
Pierre
Stefan Karrmann wrote:
Hello Pierre,
Pierre Casteran (Mon, Jun 14, 2004 at 07:45:06AM +0200):
as a newbie to coq I have some questions. As I'm used to functional
programs I tried to start with function definitions and extraction.
How can I switch from coq's nat to Haskell's Integer type? The former
uses much more memory.
How can I define recursive functions, e.g. the Ackermann function?
I found a definition which uses streams, but my try to define it
directly failed. Where can I find some hints? Is well-foundmess (Wf)
the right starting point?
It also possible to use a well founded order on pairs of natural numbers (using Coq standard library) and define ackerman of type
nat * nat -> nat (or Z * Z -> Z)
How can this be coded? The key relation is:
Definition A : Set := pair nat nat.
Definition R (x:A)(y:A) : Prop := ((fst x) < (fst y))
   \/ ((fst x = fst y)
      /\ (snd x < snd y) ).
Module Ackermann.
ackermann 0 n = n+1
ackermann m 0 = ackermann (m-1) 1
ackermann m n = ackermann (m-1) (ackermann m (n-1))
Section Ackermann2.
Require Import Wf.
Definition A : Set := prod nat nat.
Definition P (A:Set) : Type := nat.
Definition R (x y : A) : Prop :=
 ((fst x) < (fst y))
 \/ ((fst x = fst y)
Definition F (x:A) (f: A -> nat) : nat :=
 match x with
 | (0,n) => n+1
 | (m,0) => f (m-1,1)
 | (m,n) => f (m-1,f (m,n-1))
 end.
End Ackermann2.
End Ackermann.
Pierre Casteran,
LaBRI, Universite Bordeaux-I      |
351 Cours de la Liberation        |
F-33405 TALENCE Cedex             |
France                            |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri .  fr  (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
