coq-club - Re: [Coq-Club] Newbie - ackermann function, etc.
chronological Thread
  • To: sk AT mathematik.uni-ulm.de
  • Cc: Coq-Club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Newbie - ackermann function, etc.
  • Date: Mon, 14 Jun 2004 07:45:06 +0200
  • Organization: LaBRI
Stefan Karrmann wrote:
Hello,
as a newbie to coq I have some questions. As I'm used to functional
programs I tried to start with function definitions and extraction.
How can I switch from coq's nat to Haskell's Integer type? The former
uses much more memory.
How can I define recursive functions, e.g. the Ackermann function?
I found a definition which uses streams, but my try to define it
directly failed. Where can I find some hints? Is well-foundmess (Wf)
the right starting point?
You can use also a primitive recursive polymorphic scheme
Fixpoint iterate (A:Set)(f:A->A)(n:nat)(x:A){struct n} : A :=
  match n with
  | O => x
  | S p => f (iterate A f p x)
  end.
Definition ackermann (n:nat) : nat->nat :=
  iterate (nat->nat)
          (fun (f:nat->nat)(p:nat) => iterate nat f (S p) 1)
          n
          S.
It also possible to use a well founded order on pairs of natural numbers (using Coq standard library) and define ackerman of type
nat * nat -> nat (or Z * Z -> Z)
Pierre
Module Ackermann.
ackermann 0 n = n+1
ackermann m 0 = ackermann (m-1) 1
ackermann m n = ackermann (m-1) (ackermann m (n-1))
Require Import Arith.
Section Ackermann1.
Require Import Streams.
CoFixpoint nats_from (n:nat) : Stream nat :=
   Cons n (nats_from (n+1)).
CoFixpoint col_from (n : nat)(x:Stream nat) : Stream nat :=
   let v := Str_nth n x
   in Cons v (col_from v x).
CoFixpoint ack_from (c:Stream nat) : Stream (Stream nat) :=
   Cons c (ack_from (col_from 1 c)).
Definition ack_tab : Stream (Stream nat) :=
   ack_from (nats_from 1).
Definition ack (m n : nat) : nat :=
   Str_nth n (Str_nth m ack_tab).
(* Eval compute in ack 2 2.  *)
End Ackermann1.
Extraction "ackermann" ack.
Extraction Language Haskell.
Section Ackermann2.
Require Import Wf.
Definition A : Set := prod nat nat.
Definition P (A:Set) : Type := nat.
Definition R (x y : A) : Prop :=
   ((fst x) < (fst y))
   \/ ((fst x = fst y)
      /\ (snd x < snd y) ).
Definition F (x:A) (f: A -> nat) : nat :=
   match x with
   | (0,n) => n+1
   | (m,0) => f (m-1,1)
   | (m,n) => f (m-1,f (m,n-1))
   end.
This fails:
Fixpoint ack' (x:A) : nat :=
   F x ack'.
Definition ack2 (m n:nat):nat :=
   ack' (m,n).
End Ackermann2.
End Ackermann.
Sincerly,
Pierre Casteran,
LaBRI, Universite Bordeaux-I      |
351 Cours de la Liberation        |
F-33405 TALENCE Cedex             |
France                            |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri .  fr  (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
