coq-club - [Coq-Club] Re: [Flint-core] Dependent elimination question?
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: flint-core AT cs.yale.edu
  • Subject: [Coq-Club] Re: [Flint-core] Dependent elimination question?
  • Date: Thu, 3 Feb 2005 15:11:55 -0500 (EST)
My question is apparently ill-phrased:
Given the way I define R in the last message:
   Definition F (A B : Set) (x : A) (y : R(A->B)) : R(B) :=
      match y with
        Rep y0 => Rep B (y0 x)
      end.
apparently works fine.
But if I define R differently as RR:
   Inductive RR : Set -> Type :=
         RRep : forall A : Set, A -> RR(A).
Then my above definition "F" will be hard to write, since RRep
needs to take the explicit type argument (which is hard to
specify)
   Definition F (A B : Set) (x : A) (y : RR(A->B)) : RR(B) :=
      match y with
        RRep _ y0 => RRep B (y0 x)
      end.
So there is a subtle difference between these two definitions R
and RR.
-Zhong
|> Hi, given the following induction definition:
|>    Inductive R (A : Set) : Type :=
|>         Rep : A -> R(A).
|> assume that Set is a predicative universe (as in Coq 8.0),
|> Can I write a function F with the following type:
|>             (forall A B : Set) A -> R(A -> B) -> R(B)
|> The naive way is to write it as:
|>      match y with
|>        Rep y0 => Rep (y0 x)
|>      end.
|> which of course does not work since y0 does not has type A->B.
|> Thanks a lot,
|> -Zhong Shao
(shao-zhong AT cs.yale.edu)
|> _______________________________________________
|> Flint-core mailing list
Flint-core AT cs.yale.edu
|> http://netra.cs.yale.edu/mailman/listinfo/flint-core
