- To: <shao-zhong AT cs.yale.edu>, <coq-club AT pauillac.inria.fr>
- Cc: <flint-core AT cs.yale.edu>
- Subject: [Coq-Club] Re: [Flint-core] Dependent elimination question?
- Date: Thu, 3 Feb 2005 15:37:44 -0500
The following works in this case:
Definition F (A B : Set) (x : A) (y : RR(A->B)) : RR(B) :=
match y in RR(C) return C=(A->B) -> RR(B) with
RRep C y0 => fun pf => RRep B (eq_rect C (fun T => T) y0 (A->B) pf x)
end (refl_equal (A->B)).
-Zhaozhong
----- Original Message ----- From: "Zhong Shao" <shao AT cs.yale.edu>
To:
Cc:
Sent: Thursday, February 03, 2005 3:11 PM
Subject: Re: [Flint-core] Dependent elimination question?
My question is apparently ill-phrased:
Given the way I define R in the last message:
Definition F (A B : Set) (x : A) (y : R(A->B)) : R(B) := match y with Rep y0 => Rep B (y0 x)
end.
apparently works fine.
But if I define R differently as RR:
Inductive RR : Set -> Type := RRep : forall A : Set, A -> RR(A).
Then my above definition "F" will be hard to write, since RRep
needs to take the explicit type argument (which is hard to
specify)
Definition F (A B : Set) (x : A) (y : RR(A->B)) : RR(B) := match y with RRep _ y0 => RRep B (y0 x)
end.
So there is a subtle difference between these two definitions R and RR.
-Zhong
|> Hi, given the following induction definition: |> |> Inductive R (A : Set) : Type := |> Rep : A -> R(A).
|> |> assume that Set is a predicative universe (as in Coq 8.0),
|> |> Can I write a function F with the following type: |> |> (forall A B : Set) A -> R(A -> B) -> R(B)
|> |> The naive way is to write it as: |> |> Definition F (A B : Set) (x : A) (y : R(A->B)) : R(B) := |> match y with |> Rep y0 => Rep (y0 x)
|> end.
|> |> which of course does not work since y0 does not has type A->B.
|> |> Thanks a lot,
|> |> -Zhong Shao
(shao-zhong AT cs.yale.edu)
|> _______________________________________________
|> Flint-core mailing list
Flint-core AT cs.yale.edu
|> http://netra.cs.yale.edu/mailman/listinfo/flint-core
- [Coq-Club] Dependent elimination question?, Zhong Shao
- [Coq-Club] Re: [Flint-core] Dependent elimination question?, Zhaozhong Ni
Zhong Shao
- Re: [Coq-Club] Re: [Flint-core] Dependent elimination question?, Pierre Casteran
