- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] type error - perhaps bug in coq?
- Date: Tue, 12 Apr 2005 14:40:02 +0200
Below is a simple definition of a function "test" which works. However if the comment around
the type specification is uncommented then coq outputs the error below. Since this is the type that coq outputs anyway when asked using Check, it is quiet confusing:
The term
"match t in (Test b1) return (if b1 then bool else nat) with
| ta => true
| tb => 1
end" has type "if c then bool else nat" while it is expected to have type
Inductive Test:bool-> Set := ta:Test true | tb : Test false.
Definition test (c:bool)(t:Test c) (* : if c then bool else nat*) :=
match t in Test b1 return (if b1 then bool else nat) with
ta => true
| tb => 1
end.
Check test.
(* Outputs test
: forall c : bool, Test c -> if c then bool else nat *)
- [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Virgile Prevosto
Andrew McCreight
- Re: [Coq-Club] type error - perhaps bug in coq?, Pierre Casteran
