- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Andrew McCreight <andrew.mccreight AT yale.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] type error - perhaps bug in coq?
- Date: Wed, 13 Apr 2005 15:25:45 +0200
Selon Andrew McCreight
<andrew.mccreight AT yale.edu>:
> ...which is a bit more illuminative.
It seems indeed to be a problem of coercion:
The two versions of test check perfectly :
Definition test (c:bool)(t:Test c) : ((if c then bool else nat) : Type) :=
match t in Test b1 return (if b1 then bool else nat) with
ta => true
| tb => 1
end.
Definition test' (c:bool)(t:Test c) : (if c then bool else nat) :=
match t in Test b1 return ((if b1 then bool else nat):Set) with
ta => true
| tb => 1
end.
But let us check the if expression alone :
Variable b : bool.
Check (if b then nat else bool).
: Set
Pierre
> -Andrew
> On Tue, 12 Apr 2005, Dan Synek wrote:
> > Below is a simple definition of a function "test" which works. However
> > if the comment around
> > the type specification is uncommented then coq outputs the error below.
> > Since this is the type that coq outputs anyway when asked using Check,
> > it is quiet confusing:
> > The term
> > "match t in (Test b1) return (if b1 then bool else nat) with
> > | ta => true
> > | tb => 1
> > end" has type "if c then bool else nat" while it is expected to have
> > type
> > Inductive Test:bool-> Set := ta:Test true | tb : Test false.
> > Definition test (c:bool)(t:Test c) (* : if c then bool else nat*) :=
> > ta => true
> > | tb => 1
> > end.
> > Check test.
> > (* Outputs test
> > : forall c : bool, Test c -> if c then bool else nat *)
> > Bug reports: http://coq.inria.fr/bin/coq-bugs
> > Archives: http://pauillac.inria.fr/pipermail/coq-club
> > http://pauillac.inria.fr/bin/wilma/coq-club
> > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Casteran
http://www.labri.fr/Perso/~casteran/
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Virgile Prevosto
Andrew McCreight
- Re: [Coq-Club] type error - perhaps bug in coq?, Pierre Casteran
