- From: Andrew McCreight <andrew.mccreight AT yale.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] type error - perhaps bug in coq?
- Date: Wed, 13 Apr 2005 09:10:56 -0400 (EDT)
If you do
Set Printing All.
then you get the error message:
The term
"match
t in (Test b)
return match b return Type with
| true => bool
| false => nat
end
with
| ta => true
| tb => S O
end" has type "match c return Type with
| true => bool
| false => nat
end" while it is expected to have type
"match c return Set with
| true => bool
| false => nat
end"
...which is a bit more illuminative.
-Andrew
On Tue, 12 Apr 2005, Dan Synek wrote:
> Below is a simple definition of a function "test" which works. However
> if the comment around
> the type specification is uncommented then coq outputs the error below.
> Since this is the type that coq outputs anyway when asked using Check,
> it is quiet confusing:
> The term
> "match t in (Test b1) return (if b1 then bool else nat) with
> | ta => true
> | tb => 1
> end" has type "if c then bool else nat" while it is expected to have type
> Inductive Test:bool-> Set := ta:Test true | tb : Test false.
> Definition test (c:bool)(t:Test c) (* : if c then bool else nat*) :=
> match t in Test b1 return (if b1 then bool else nat) with
> ta => true
> | tb => 1
> end.
> Check test.
> (* Outputs test
> : forall c : bool, Test c -> if c then bool else nat *)
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Virgile Prevosto
- Re: [Coq-Club] type error - perhaps bug in coq?, Andrew McCreight
- Re: [Coq-Club] type error - perhaps bug in coq?, Pierre Casteran
