- To: synek AT cs.ru.nl
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] type error - perhaps bug in coq?
- Date: Wed, 13 Apr 2005 14:19:46 +0200
I was told by Iris Loeb here locally that if I read the manual I would fint out that I need to add
a return statement to the if statement.
Definition test (c:bool)(t:Test c) : if c return Type then bool else nat :=
match t in Test b1 return (if b1 then bool else nat) with
ta => true
| tb => 1
end.
She also told me I would get a better type from the check statement if I first did:
Unset Printing Synth.
Dan Synek wrote:
Below is a simple definition of a function "test" which works. However if the comment around
the type specification is uncommented then coq outputs the error below. Since this is the type that coq outputs anyway when asked using Check, it is quiet confusing:
The term
"match t in (Test b1) return (if b1 then bool else nat) with
| ta => true
| tb => 1
end" has type "if c then bool else nat" while it is expected to have type
Inductive Test:bool-> Set := ta:Test true | tb : Test false.
Definition test (c:bool)(t:Test c) (* : if c then bool else nat*) :=
ta => true
| tb => 1
end.
Check test.
(* Outputs test
: forall c : bool, Test c -> if c then bool else nat *)
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Dan Synek
- Re: [Coq-Club] type error - perhaps bug in coq?, Virgile Prevosto
Andrew McCreight
- Re: [Coq-Club] type error - perhaps bug in coq?, Pierre Casteran
