coq-club - Re: [Coq-Club]Inductive definitions in the Calculus of Constructionsa
chronological Thread
  • From: Benjamin Werner <Benjamin.werner AT inria.fr>
  • To: Adam Chlipala <adamc AT argus.EECS.Berkeley.EDU>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Inductive definitions in the Calculus of Constructionsa
  • Date: Sun, 15 Jan 2006 09:57:02 +0100
Hi,
Le 9 janv. 06 à 13:46, Adam Chlipala a écrit :
I know that the Calculus of Inductive Constructions was created because the Calculus of Constructions was insufficient to represent some inductive types. Can anyone on this list give a short characterization of which types require this extension, and/or perhaps the simplest example of such a type?
It is not so much the question of "which types" but rather what you can do with them. Without inductive types, i.e. in raw CC, you :
* cannot prove 0 \neq 1
* cannot prove the induction scheme (or dependent matching for the matter)
* do not have constant-time reduction for the matching, and matching only works for closed terms.
You can get back some of the results in CC through mere axioms. But not the reduction behavior.
Cheers,
Benjamin
I'm interested in this in the context of trying to minimize the trusted code base needed to use results proved with Coq. If compiled developments can be translated to the Calculus of Constructions, then I imagine it's possible to use a significantly simpler checker.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
