- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Inductive definitions in the Calculus of Constructions
- Date: Tue, 17 Jan 2006 06:10:41 -0800
Pierre Casteran wrote:
Hi,
Notice that your definitions make False, True, 0 <> 1 being inhabitants of Type (with some index >0), and
not plain propositions (i.e. of type Prop( at its turn of type Type(0)).
Check (True:Prop).
Toplevel input, characters 837-841
> Check (True:Prop).
Error: The term "True" has type "Type" while it is expected to have type
"Prop"
Is this really a problem? In my long journey towards understanding the metatheory of Coq, I've come to explain to myself the distinction among Set/Prop/Type as only being necessary to support extraction. Do you really need more than the different levels of Type if you're only interested in checking proofs in the simplest possible calculus?
- [Coq-Club]Inductive definitions in the Calculus of Constructionsa, Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructionsa,
Benjamin Werner
Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructions,
Adam Chlipala
Pierre Casteran
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructions, Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructions, Frederic Blanqui
Pierre Casteran
Adam Chlipala
Adam Chlipala
Benjamin Werner
