coq-club - Re: [Coq-Club]Inductive definitions in the Calculus of Constructions
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Adam Chlipala <adamc AT cs.berkeley.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Inductive definitions in the Calculus of Constructions
  • Date: Tue, 17 Jan 2006 07:46:36 +0100
Benjamin Werner wrote:
It is not so much the question of "which types" but rather what you can do with them. Without inductive types, i.e. in raw CC, you :
I think I've below defined True, False, eq, and nat without using inductive definitions or axioms. I'm able to prove 0 \neq 1, and the induction scheme follows trivially from my definition of nat.
Oops. I see that only the non-dependently-typed recursion principle follows trivially, which I think is enough for "programming" but not "proving" with nats. It still looks to me like I have a faithful encoding of nat in some sense, and I'm able to prove 0 \neq 1 about it.
Hi,
Notice that your definitions make False, True, 0 <> 1 being inhabitants of Type (with some index >0), and
not plain propositions (i.e. of type Prop( at its turn of type Type(0)).
Check (True:Prop).
Toplevel input, characters 837-841
> Check (True:Prop).
Error: The term "True" has type "Type" while it is expected to have type
"Prop"
Pierre
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
