- From: Frederic Blanqui <Frederic.Blanqui AT loria.fr>
- To: Adam Chlipala <adamc AT cs.berkeley.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Inductive definitions in the Calculus of Constructions
- Date: Tue, 17 Jan 2006 17:28:57 +0100 (CET)
On Tue, 17 Jan 2006, Adam Chlipala wrote:
Is this really a problem? In my long journey towards understanding the metatheory of Coq, I've come to explain to myself the distinction among Set/Prop/Type as only being necessary to support extraction. Do you really need more than the different levels of Type if you're only interested in checking proofs in the simplest possible calculus?
the Type hierarchy is predicative while Prop is impredicative. this means that (forall P : Prop, P => P) is of type Prop, while (forall P : Type_i, P => P) is of type Type_i+1. i explicitly added the indexes which are not printed by coq.
- [Coq-Club]Inductive definitions in the Calculus of Constructionsa, Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructionsa,
Benjamin Werner
Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructions,
Adam Chlipala
Pierre Casteran
Adam Chlipala
- Re: [Coq-Club]Inductive definitions in the Calculus of Constructions, Frederic Blanqui
Adam Chlipala
Pierre Casteran
Adam Chlipala
Adam Chlipala
Benjamin Werner
