- Cc: Coq List <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]How do I prove this simple fact?
- Date: Wed, 08 Nov 2006 09:32:52 -0800
Aaron Bohannon wrote:
Given the simple inductive definition here, I would like to prove the
simple lemma below it.
Inductive foo : nat * nat -> Prop :=
| foo1 : forall i j k, i = j + k -> foo (i, j)
| foo2 : forall i j k, foo (i, j + k) -> foo (i, j).
Lemma bar : forall n m, foo (n, m) -> m <= n.
You have here a classic problem resulting from the 'induction' tactic's excessive optimism. It drops all facts about the structure of the arguments to the inductive type whose derivations you want to induct over. Instead, it perhaps should fail or at least raise a warning when the inductee has some argument that isn't a variable. Here's an instantiation of the standard workaround:
Ltac injecter :=
match goal with
| [ H : (_, _) = (_, _) |- _ ] =>
injection H; clear H; intros; subst
end.
Lemma bar' : forall nm, foo nm
-> forall n m, nm = (n, m)
-> m <= n.
induction 1; intuition; injecter; subst;
eauto with arith.
Qed.
-> m <= n.
intros.
eapply bar'; eauto.
Qed.
- [Coq-Club]How do I prove this simple fact?, Aaron Bohannon
- Re: [Coq-Club]How do I prove this simple fact?, Adam Chlipala
- Re: [Coq-Club]How do I prove this simple fact?, Andrew McCreight
- Re: [Coq-Club]How do I prove this simple fact?, Thery Laurent
- Re: [Coq-Club]How do I prove this simple fact?, jean-francois . monin
- [Coq-Club]Re: How do I prove this simple fact?,
Aaron Bohannon
- Re: [Coq-Club]Re: How do I prove this simple fact?,
Pierre Casteran
- Re: [Coq-Club]Re: How do I prove this simple fact?, Pierre Casteran
- Re: [Coq-Club]Re: How do I prove this simple fact?, jean-francois . monin
- Re: [Coq-Club]Re: How do I prove this simple fact?, Thery Laurent
Pierre Casteran
