- To: "Aaron Bohannon" <bohannon AT cis.upenn.edu>
- Cc: "Coq List" <coq-club AT pauillac.inria.fr>, Thery Laurent <thery AT ns.di.univaq.it>
- Subject: Re: [Coq-Club]How do I prove this simple fact?
- Date: Wed, 8 Nov 2006 23:43:20 +0100
Hello,
You can actually use your own script with a small and natural
change. The point is that induction is carried out over (n,m);
then just replace, in your goal, occurrences of n (and of m) by
appropriate functions of (n,m).
Lemma bar : forall n m, foo (n, m) -> m <= n.
Proof.
intros n m H.
change (snd (n,m) <= fst (n,m)). (* 2 *)
induction H; simpl in *|-*.
rewrite H; auto with arith.
eauto with arith.
Qed.
PS. Wish to the attention of the Coq development team.
We still lack a conversion tactic similar to "replace... with..."
I would prefer to express line (* 2 *) above in the following
way:
convert n to (fst (n,m)) and m to (fst (n,m)). (* 2' *)
(Note that simultaneous conversion is needed, hence the "and")
I very often need this, and claim that most uses of "change" (if
not all) can be advantageously be replaced by convert: "change"
is bad for the robustness of scripts. Using "replace... with..."
is robust but not satisfactory for 2 reasons at least:
- no parallel replace is available;
- equality is heavier than conversion.
Cheers,
JF
Aaron Bohannon a ecrit :
> Given the simple inductive definition here, I would like to prove the
> simple lemma below it.
> Inductive foo : nat * nat -> Prop :=
> | foo1 : forall i j k, i = j + k -> foo (i, j)
> | foo2 : forall i j k, foo (i, j + k) -> foo (i, j).
> However, I have not found any way to make the induction work. I run
> into different problems depending on what I try, and all of my
> attempts have looked rather ugly. So I am wondering what the "right"
> way to prove this is.
> Of course, it is trivial proof if we use the "curried" form of the
> definition:
> Inductive foo : nat -> nat -> Prop :=
> | foo1 : forall i j k, i = j + k -> foo i j
> | foo2 : forall i j k, foo i (j + k) -> foo i j.
> Lemma bar : forall n m, foo n m -> m <= n.
> Proof.
> intros n m H.
> induction H.
> eauto with arith.
> Qed.
> But, for the sake of argument, let's say that I can't or don't want to
> write the definition in that way.
> Thanks in advance for any help.
> -Aaron
Thery Laurent a ecrit :
> Hi,
> the problem comes from the fact that you are using pairing.
> You then need to tell Coq explicitly that
> m <= n is the same than (fun p => snd p <= fst p) (n,m)
> so that induction proceeds as expected:
> Here it goes:
> Require Omega.
> intros n m H; change ((fun p => snd p <= fst p) (n,m)).
> elim H; simpl; intros; omega.
> Qed.
> Laurent
- [Coq-Club]How do I prove this simple fact?, Aaron Bohannon
- Re: [Coq-Club]How do I prove this simple fact?, Adam Chlipala
- Re: [Coq-Club]How do I prove this simple fact?, Andrew McCreight
- Re: [Coq-Club]How do I prove this simple fact?, Thery Laurent
- Re: [Coq-Club]How do I prove this simple fact?, jean-francois . monin
- [Coq-Club]Re: How do I prove this simple fact?,
Aaron Bohannon
- Re: [Coq-Club]Re: How do I prove this simple fact?,
Pierre Casteran
- Re: [Coq-Club]Re: How do I prove this simple fact?, Pierre Casteran
- Re: [Coq-Club]Re: How do I prove this simple fact?, jean-francois . monin
- Re: [Coq-Club]Re: How do I prove this simple fact?, Thery Laurent
Pierre Casteran
