coq-club - Re: [Coq-Club]Re: How do I prove this simple fact?
chronological Thread
  • To: Aaron Bohannon <bohannon AT cis.upenn.edu>
  • Cc: Coq List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]Re: How do I prove this simple fact?
  • Date: Thu, 9 Nov 2006 11:53:16 +0100 (CET)
Thanks for the helpful responses.  I find the use of the "change"
tactic especially elegant.  However, it does not seem applicaple to
the slightly more general case where I would like to prove:
Lemma bar : forall n m p, foo (n, m + p) -> m <= n.
Just to second jean-francois answer the problem is that you do induction on a term that does not contains only variables (there is a pair and a sum in (n, m+p)). The first way to go is to reshape your hypothesis on which you do induction so it contains only variables.
Example:
Require Import Omega.
Inductive foo : nat * nat -> Prop :=
 | foo1 : forall i j k, i = j + k -> foo (i, j)
 | foo2 : forall i j k, foo (i, j + k) -> foo (i, j).
intros n m p H.
assert (Haux: forall u, foo u -> forall p, u = (n, m + p) -> m <= n).
  intros u Hu; elim Hu; intros i j k.
    intros Eq1 p1 Eq2; injection Eq2; intros; omega.
  intros _ Hrec p1 Eq2; apply Hrec with (p1 + k).
  apply f_equal2 with (f := @pair nat nat); injection Eq2; intros; omega.
apply Haux with (1 := H) (p := p); trivial.
Qed.
The second way to go is to reshape your conclusion so it explicitly
exhibits the dependancy with the term that is not a variable
in your case (n, m + p). Example:
Lemma bar1 : forall n m p, foo (n, m + p) -> m <= n.
intros n m p H.
replace m with ((m + p) - p); try omega.
change ((fun x => (snd x - p <= fst x)) (n, m + p)).
elim H; simpl; intros; omega.
Qed.
Laurent
