- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]instantiating an inner existential
- Date: Thu, 01 Feb 2007 13:51:43 +0900 (JST)
Thank you for giving me several ways of solving my question.
As Benjamin wrote, Pierre's answer may not be very precise, but is
useful to my situation. Indeed I first tried Pierre's suggestion
because it seemed to require the least overhead and it worked well for
my particular subgoal. At the same time, I found a few disadvantages
of ex_intro:
- (major) Instantiations may not propagate into other subgoals.
For instance,
Goal exists x:nat, exists y : nat, y*y = x /\ x = 9.
eapply ex_intro.
exists 3.
split.
Focus 2.
apply refl_equal.
At this point, I get a subgoal containing a non-instantiated variable, which
must have been instantiated by the last command "apply refl_equal.".
This is quite unhelpful.
- (minor) I may end up unawarely with a proof containing
non-instantiated variable.
- (minor) Successive uses of ex_intro can produce hard-to-read subgoals
containing several occurrences of ?11, ?12, ?13, etc..
- (As Benjamin pointed out)
Parameters P Q R : Prop.
Parameter H : exists i : nat, (P /\ 3 = 3).
Goal exists i : nat, (P /\ (exists j : nat, j = 3)).
eapply ex_intro.
I cannot use H anymore...
Many of my Lemmas contain deeply nested existentials and more than 5
conjunctions. So I will choose a better one among your suggestions,
depending on the complexity of my subgoals.
Thank you.
With best regards,
Keiko.
- Re: [Coq-Club]instantiating an inner existential, Keiko Nakata
Pierre Casteran
Lionel Elie Mamane
- [Coq-Club]Is extensionality required ?,
Eric Jaeger
- [Coq-Club]Re: Is extensionality required ?, Lionel Elie Mamane
Eric Jaeger
Lionel Elie Mamane
Pierre Casteran
