coq-club - Re: [Coq-Club]instantiating an inner existential
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>, Benjamin Werner <benjamin.werner AT inria.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]instantiating an inner existential
  • Date: Thu, 01 Feb 2007 08:46:14 +0100
Hi, Keiko and Benjamin
On the specific point of instantiation propagation :
Keiko Nakata wrote:
- (major) Instantiations may not propagate into other subgoals. For instance,
 Goal exists x:nat, exists y : nat, y*y = x /\ x = 9.
 eapply ex_intro.
 exists 3.
 split.
 Focus 2.
 apply refl_equal.
At this point, I get a subgoal containing a non-instantiated variable, which
must have been instantiated by the last command "apply refl_equal.".
This is quite unhelpful.
I tried your example (with a very slight change : Focus was removed in order to display all subgoals) and after the
tactic call "eapply refl_equal" Coq instantiated the existential variable in the first subgoal.
 eapply ex_intro.
 exists 3.
 split.
 (* 2 subgoals
  3 * 3 = ?5
subgoal 2 is:
?5 = 9
 2:  eapply refl_equal.
1 subgoal
  3 * 3 = 9
 trivial.
Qed.
On the other points, you are right.
- (minor) I may end up unawarely with a proof containing
non-instantiated variable.
In the following example, the variable "i" is not used in the formulas (P /\ (exists j : nat, j = 3)) and (P /\ 3 = 3).
Therefore, solving suboals like (P /\ (exists j : nat, j = 3)) won't help to instantiate "i" ; this is the situation you
describe.
 Parameters P Q R : Prop.
 Parameter H : exists i : nat, (P /\ 3 = 3).
 Goal exists i : nat, (P /\ (exists j : nat, j = 3)).
 eapply ex_intro.
I cannot use H anymore...
More generally, if you have an hypothesis of the form "exists i, P i " and a goal of the form "exists i, Q i", I must
(even using ex_intro) eliminate first H. (I think that's what Benjamin meant). When I was experimenting with Isabelle, this was the way I had to work. On the other hand, it should be interesting to have a tactic for permuting nested quantifiers whenever possible, but I am not very expert in writing tactics in Ltac.
Many of my Lemmas contain deeply nested existentials and more than 5
conjunctions. So I will choose a better one among your suggestions, depending on the complexity of my subgoals.
If this situation occurs too often, it should be interesting to rearrange your lemmas in order to ensure that if
y depends on x, then the form (exists x, P x /\ exists y, Q x y)) is prefered to (exists y, exists x, P x /\ Q x y).
Cheers,
Pierre
