- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>, Benjamin Werner <benjamin.werner AT inria.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]instantiating an inner existential
- Date: Thu, 1 Feb 2007 09:39:14 +0100
On Thu, Feb 01, 2007 at 08:46:14AM +0100, Pierre Casteran wrote:
> On the specific point of instantiation propagation :
> Keiko Nakata wrote:
>>- (major) Instantiations may not propagate into other subgoals.
>> Goal exists x:nat, exists y : nat, y*y = x /\ x = 9.
>> eapply ex_intro.
>> exists 3.
>> split.
>> Focus 2.
>> apply refl_equal.
>> At this point, I get a subgoal containing a non-instantiated
>> variable, which must have been instantiated by the last command
>> "apply refl_equal.". This is quite unhelpful.
> I tried your example (with a very slight change : Focus was removed
> in order to display all subgoals) and after the tactic call "eapply
> refl_equal" Coq instantiated the existential variable in the first
> subgoal.
That very slight change makes the difference in Coq 8.0pl3. It is a
_bug_ that when one does the focus, it stops instantiation
propagation. Try it with the focus, you'll see. It works fine with "2:
apply refl_equal." indeed.
It seems to be corrected in svn trunk as of 10/1/2007.
Is it also being corrected for 8.0pl4?
Lionel
- Re: [Coq-Club]instantiating an inner existential, Keiko Nakata
Pierre Casteran
- Re: [Coq-Club]instantiating an inner existential, Lionel Elie Mamane
- [Coq-Club]Is extensionality required ?,
Eric Jaeger
- [Coq-Club]Re: Is extensionality required ?, Lionel Elie Mamane
Eric Jaeger
Pierre Casteran
