- To: Pierre Courtieu <pierre.courtieu AT cnam.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Property of subsubstructures
- Date: Thu, 11 Oct 2007 17:20:18 +0100
Hi,
Thanks for the quick reply!
> Indeed standard induction scheme are relatively weak compared to more
> general ones like well founded induction (see theories/Wellfounded/*.v).
Yes, but the generality of the wellfounded stuff is more than I need (I
just need an extra 'deeper' recursive call), and as you say, that makes
it more difficult.
> However they are easier to use. I suggest you use the new "Function"
> feature instead of Fixpoint. It gives you among other things a useful
> (but still in the style of L_ind) induction scheme from the function
> definition.
> Inductive L : Set :=
> | Base : L
> | Ind : L -> L.
> Function foo (l: L) : nat := match l with
> | Base => 0
> | Ind l' => match l' with
> | Base => 0
> | Ind l'' => foo l''
> end
> end.
> (* See the message for a list of things defined here. For example Check
> foo_ind *)
I'm not sure what message you are referring to here? After the Inductive
L.. definition, I get "L is defined; L_rect is defined; L_ind is
defined; L_rec is defined" but after the Function foo.. definition, I
get no messages at all (I'm using coqide, Coq version 8.1pl1).
> Theorem foo_zero : forall (l:L), foo l = 0.
> Proof.
> intros l.
> functional induction (foo l). (* this makes actually use of foo_ind,
> automatically built by Function *)
> reflexivity.
> reflexivity.
> assumption.
> Qed.
Well that was easy! Very nice. I'm not sure how it works though; what
should I read to understand "Function" and "functional induction"?
Thanks, as always much appreciated!
Edsko
- [Coq-Club] Property of subsubstructures, Edsko de Vries
- Re: [Coq-Club] Property of subsubstructures,
Pierre Courtieu
- Re: [Coq-Club] Property of subsubstructures, Edsko de Vries
Pierre Courtieu
- Re: [Coq-Club] Property of subsubstructures, Pierre Courtieu
Pierre Courtieu
Edsko de Vries
- Re: [Coq-Club] Property of subsubstructures, Jean-Francois Monin
- Re: [Coq-Club] Property of subsubstructures, Matthieu Sozeau
- <Possible follow-ups>
Santiago Zanella
Pierre Courtieu
