coq-club - Re: [Coq-Club] Property of subsubstructures
chronological Thread
  • To: Edsko de Vries <edsko AT edsko.net>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Property of subsubstructures
  • Date: Sat, 13 Oct 2007 17:11:30 +0200
  • Organization: LRI
Edsko de Vries a écrit :
Hi,
Suppose we have a definition such as
Inductive L : Set := | Base : L
  | Ind : L -> L.
Then when we do a proof by induction on L, for the 'Ind' case, the induction
principle derived by Coq tells me that the property holds for the sub-L.
However, what if we need to know that the property holds for a sub-sub-L? For
example, consider
Fixpoint foo (l: L) : nat := match l with
  | Base => 0
  | Ind l' => match l' with
    | Base => 0
    | Ind l'' => foo l''
    end
end.
Theorem foo_zero : forall (l:L), foo l = 0.
When I try to do a normal proof by induction, the induction hypothesis is no
use in the Ind Ind case:
Proof.
induction l.
reflexivity.
induction l.
reflexivity.
simpl.
1 subgoal
l : L
IHl : foo (Ind l) = 0
IHl0 : foo l = 0 -> foo (Ind l) = 0
______________________________________(1/1)
foo l = 0
At which point we're stuck (I think?). Now, up until recently the
'induction principle' was a bit of magic to me, until I realised that it
was simply a fold (in the functional programming sense), and that so it
must be possible to define these proofs directly. Indeed, I can prove
foo_zero as follows:
Proof.
refine (fix f (l:L) : foo l = 0 := _).
elim l.
reflexivity.
intros.
elim l0.
reflexivity.
intros.
simpl.
apply f.
Qed.
Although I'm quite happy I understood this, I would still like to be able to
use the proof style of the first attempt. Is it possible?
As previous posters indicated, functional induction permits to do that by generating an induction principle derived from the function.
Alternatively, you could define foo and prove it has the expected property at the same time using dependently-typed programming. E.g, using the Program extension:
 | Base : L
 | Ind : L -> L.
Obligations Tactic := idtac.
Program Fixpoint foo (l: L) : { r : nat | r = 0 } := match l with
 | Base => 0
   | Base => 0
   end
 end.
Obligations.
Solve Obligations using reflexivity.
If you do not change the default obligations tactic to a dummy they are solved automatically.
Another way would be to define the induction principle by hand, keeping the original definition of foo. e.g:
Require Import Coq.Program.Program.
Obligations Tactic := program_simpl.
Program Fixpoint L_ind' (P : L -> Prop)
(pbase : P Base) (pbase2 : P (Ind Base)) (pind : forall l : L, P l -> P (Ind (Ind l))) (l : L) {struct l}: P l :=
 match l with
   | Base => pbase
   | Ind l' =>
     match l' with
       | Base => pbase2
       | Ind l'' => pind l'' (L_ind' P pbase pbase2 pind l'')
     end
 end.
Lemma foo_0 : forall l, foo l = 0.
Proof.
 induction l using L_ind' ; simpl ; trivial.
Qed.
You can even get by without using Program or writting ugly terms in this case with:
 (pbase : P Base)
 match l return P l with
   | Base => pbase
   | Ind Base => pbase2
   | Ind (Ind l') => pind l' (L_ind' P pbase pbase2 pind l')
 end.
I'm not sure such an induction principle would be generaly useful in your case though...
Hope this helps,
Matthieu Sozeau
http://www.lri.fr/~sozeau
