coq-club - Re: [Coq-Club] Property of subsubstructures
chronological Thread
  • From: Santiago Zanella <Santiago.Zanella AT sophia.inria.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Property of subsubstructures
  • Date: Fri, 12 Oct 2007 15:59:52 +0200
You can always write your own induction principle or make your goal
stronger as Jean-Francois Monin suggested.
Inductive L : Set :=
  | Base : L
  | Ind : L -> L.
Inductive Foo : L -> nat -> Prop :=
  | FooBase : Foo Base 0
  | FooIndBase : Foo (Ind Base) 0
  | FooIndInd : forall (l: L), Foo l 0 -> Foo (Ind (Ind l)) 0.
Definition Lind (P:L -> Prop)
 (f:P Base)
 (f0:P (Ind Base))
 (f1:forall l, P l -> P (Ind (Ind l))) :=
 fix F (l:L) : P l :=
  match l return (P l) with
   | Base => f
   | Ind Base => f0
   | Ind (Ind l) => f1 l (F l)
  end.
Hint Constructors Foo.
Theorem foo : forall (l:L), Foo l 0.
 induction l using Lind; auto.
Qed.
Theorem foo' : forall (l:L), Foo l 0.
 assert (forall l, Foo l 0 /\ Foo (Ind l) 0) by (induction l;
intuition).
 firstorder.
Qed.
On Fri, 2007-10-12 at 13:02 +0100, Edsko de Vries wrote:
> Hey,
> The Function/functional induction very nicely solved the problem. I was
> wondering if there is a similar thing I can use in this minor variation:
>   | Base : L
>   | Ind : L -> L.
> Again, normal proof by induction is no use:
> Proof.
> induction l.
> apply FooBase.
> induction l.
> apply FooIndBase.
> apply FooIndInd.
> 1 subgoal
> l : L
> IHl : Foo (Ind l) 0
> IHl0 : Foo l 0 -> Foo (Ind l) 0
> ______________________________________(1/1)
> Foo l 0
> But when I do the recursion manually, the proof works:
> Proof.
> refine(fix f (l:L) : Foo l 0 := _).
> elim l.
> apply FooBase.
> intros.
> elim l0.
> apply FooIndBase.
> intros.
> apply FooIndInd.
> apply f.
> Qed.
> Of course I just use this style (using the refine to give me access to the
> recursive calls to the proof), but it just seems to me there should be an
> easier way.
> Edsko
