- To: Robin Green <greenrd AT greenrd.org>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] eauto and avoiding non-instantiated existential variables
- Date: Thu, 8 Nov 2007 21:23:15 -0500
On Nov 8, 2007, at 2:09 PM, Robin Green wrote:
I am getting the error about non-instantiated existential variables[1]
after using eauto sometimes, and I have the following two
questions:
1. I'm not sure what this means.
Suppose we have
Lemma foo: forall x y, P x y -> Q x.
If we use (eapply foo) when the conclusion of the current goal is (Q x), we will get a new goal (P x ?23), where ?23 is an automatically generated existential variable. The problem is that the conclusion of the goal, (Q x), doesn't determine what y should be in foo. The existential variable is a placeholder that will be filled in through unification, hopefully. Sometimes it is not, hence "non-instantiated existential variables."
Would allowing uninstantiated existentials in proofs mean that false conclusions could be proven? (I presume so, otherwise why would it be disallowed?)
An existential variable can be viewed as a proof obligation: find me a term that has this particular type, because I need it to fill in all the details of this proof. If the type is empty (which is certainly possible in Coq), then you won't be able to find such a term and hence complete the proof. So Coq requires that you show the type is non-empty.
If so, can someone give a simple example of a proof script with an uninstantiated existential, which constitutes a bogus "proof" of a false statement?
Here's a contrived example:
Definition P (x : Empty_set) := True.
(* Empty_set is defined as
Inductive Empty_set := .
It's uninhabited, which is why the following is ok.
Lemma baz: forall (y : Empty_set), P y -> False.
Proof. intros y H. inversion y. Qed.
Lemma foo: False.
Proof. eapply baz. unfold P. trivial. Qed. (* fails, thankfully *)
2. Is there a technique to get eauto to avoid possible proofs which leave existential variables instantiated? Right now, I am just reducing the proof search depth, which works for these particular cases, but is a total hack. Maybe there are certain lemmas which I should avoid adding as hints?
In my experience, doing the following is a bad idea.
[1] Prove a lemma that looks like: forall x y, Q x y -> P x.
[2] Prove a lemma that looks like: forall x y, P x -> Q x y.
[3] Add *both* lemmas as hints.
When trying to solve a goal (P z), eauto may apply [1], then [2], and then solve (P z) some other way. In the end, the proof is rather silly *and* that intermediate variable y remains a non-instantiated existential variable. I've seen this happen, at least in earlier versions of Coq.
Cheers,
Brian
- [Coq-Club] eauto and avoiding non-instantiated existential variables, Robin Green
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Brian Aydemir
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Vasileios Koutavas
- Re: [Coq-Club] eauto and avoiding non-instantiated existential variables, Arnaud Spiwack
