coq-club - [Coq-Club] Re: Dealing with equivalence classes
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: Dealing with equivalence classes
  • Date: Wed, 06 Feb 2008 17:36:26 -0800
  • Cancel-lock: sha1:52/mFUwhcNJDbrHC06u27/dZmCs=
  • Organization: Myself
Edsko de Vries
<devriese AT cs.tcd.ie>
 writes:
> It would be far nicer if I could have the property (*), above. One way
> to do this would be to deal with equivalence classes instead; so the
> equivalence class for 'true' is the same as the equivalence class for
> 'or true true'.
You might find Add Relation, Setoid, and Ring helpful.
  Require Import Setoid.
  Require Import Ring.
  Require Import Ring_tac.
Your definition makes it easy to convince Coq that equiv is in fact an
equivalence relation:
  Add Relation trm equiv
    reflexivity  proved by refl
    symmetry     proved by sym
    transitivity proved by trans
    as equiv_relation.
Assuming you are able to show that or/and/not are equiv-respecting
morphisms:
  Add Morphism or with signature equiv ==> equiv ==> equiv as or_morphism.
    Admitted.
  Add Morphism and with signature equiv ==> equiv ==> equiv as and_morphism.
    Admitted.
  Add Morphism not with signature equiv ==> equiv as not_morphism.
    Admitted.
you'll be able to use rewrite on terms consisting of equiv and those
morphisms:
  Lemma complement_unique : (* ... *)
    intros.
    assert(equiv a'' (or a'' a')).
    rewrite <- (id_or a'').
    rewrite <- H0.
    rewrite distr_or.
You may also benefit from the fact that boolean algebras are rings,
starting like this (although I didn't go very far with it).
  (* symmetric difference *)
  Definition plus := fun a b => or (and a (not b)) (and (not a) b).
  Add Morphism plus with signature equiv ==> equiv ==> equiv as plus_morphism.
    Admitted.
  Theorem GoodsteinRingTheory :
    ring_theory false true plus and (fun x y => plus x (not y)) not equiv.
    Admitted.
  Add Ring AR : GoodsteinRingTheory.
This should let you use the ring_simplify tactic on values of type trm.
  - a
