coq-club - Re: [Coq-Club] Re: Dealing with equivalence classes
chronological Thread
  • From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: Adam Megacz <megacz AT cs.berkeley.edu>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Re: Dealing with equivalence classes
  • Date: Thu, 07 Feb 2008 23:51:36 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:cc:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=Y6NnA/oYXljWJU8dKaR65t6QRKmjD7E+jlUxSSAz/B0XdzeTmnITvAt5xJ32tNkiXcQjGmowuHFWILHzg7onvo9p3y1QitL5sutOK5kQqITvDTnv9Yy2F8zlw+knbtiAqo6DliDjSYNv6f1v/N3Xm5K8zcLWG9PvDXOy0TJN/78=
To reason with setoids, you may need to re-think your maths a bit. Setoids are close to set-theory, but they work in a very different mindset. However, they provide in practice a very good interaction between more-or-less-common mathematics and programming. In usual mathematics, you tend to consider that things are equal a priori, in programming on the other hand, you consider that things have a representation, and consider a notion of equality a posteriori.
Setoids can be seen as the mathematical way of speaking of the latter.
Now for your case, the answer is reasonably simple. To be able to handle a setoid situation, your predicate typeof needs itself to be morphism from the environments/terms/types to the setoid often called Omega, that is Prop, together with the equivalence ( (<->) or iff in Coq). Your proposal for typeof, seems not to be, so you'll have to rewrite it so that things fit (you will probably need to introduce more equivalences inside your definitional cases, a possibility is adding a case that specifically handles converting a type to another if they are equivalent).
In any case, once you know that typeof is a morphism, then you should be able to manipulate type derivations in a rather natural way.
Arnaud Spiwack
Edsko de Vries a écrit :
Hi Adam,
First, thanks for your detailed answer. Before I try and study it, can I
ask you to clarify something for me? Suppose I take the approach using
setoids. The boolean algebra stuff is only a minor part of a larger
formalization of my type system. In my type system, types consist of a
base type (such as Int) and a uniqueness attribute (which is just a term
in a boolean algebra). Now suppose I have
  x :: Int:Or True True
(that is, a variable x in my term language whose type consists of the
base type 'Int' and the attribute 'Or True True', a boolean term), and
  f :: Int:True -> Int:True
My typing rule looks something like
  G |- f :: a -> b     G |- x :: a
  -------------------------------- App
           G |- f x :: b
(I'm simplifying quite a bit here and glossing over lots of detail); or
in Coq something like
  Inductive typeof : env -> trm -> typ -> Prop :=
    | forall (G : env) (f x : trm) (a b : typ),
        typeof G f (fn a b) ->
        typeof G x a ->
        typeof G (trm_app f x) b.
What I might want to prove (as a simple test) is that the type of 'f x'
is 'Int:True'. However, (so far at least), this proof will fail, because
the type in the domain of f (Int:True) does not match the type of x
(Int:Or True True).
This is why I wanted to deal with equivalence classes of boolean terms
instead; because then the type Int:{True} (where {True} is the
equivalence class for {True}) and the type Int:{Or True True} are in
fact identical (because the equivalence class {True} and the equivalence
class {Or True True} are the same class of terms) (but I'm not sure how
to do that). One other possibility that I was considering was to
introduce a "smart" constructor for types that applies some function to
the attribute in the type to get some sort of canonical form -- but that
would involve writing that function first and proving it correct :) It
may also make other proofs more complicated, I'm not sure.
Would the setoid stuff help me here?
Thanks!
Edsko
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
